Discuss faulty RCD? in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
came across this today. washing machine repaiman had been and was getting problems with RCD tripping. the set up is 16th Ed. CU. front end 30mA RCD. MEM. 8 circuits, 2 of which are socket RFCs. in the kitchen is a 13A FCU feeding a socket under for washer. so far , so good. however, a dishwasher has been added, the socket under the worktop now feed an extension lead for both the washer and dishwasher. not ideal if they are both in use simultaneously. checked behind both the FCU and socket for trapped/skinned cables. IR tested at CU global readings L-E 5Meg. N-E 5Meg. tried a no-trip loop. .... RCD tripped. ramp tested RCD 19mA. then a normal RCD test. came up trp, with no msec. value. i have condemned the RCD> as it's an old MEM, going to replace CU for a dual RCD unit. customer is old and disabled so i think it's the best way, split the sockets and the lighting between the 2 RCDs. as it's a straightforward job ( easy access and can't see any snags) quoted him £300 tops.
Reply to faulty RCD? in the UK Electrical Forum area at ElectriciansForums.net
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
I just finished a garden room supply. The customer already had a CPN garage consumer unit that the last sparks left there, brand new in box, and...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
I’m going to call an electrician out on Monday, but curious if anyone has any ideas about this fault: I have a new kitchen fitted and two...
