Discuss Faulty treadmill motor in the UK Electrical Forum area at ElectriciansForums.net
J
j298
Hi all,
I have very little electrical understanding and I'm wondering if anyone can shed some light on a problem I'm having with the motor in a treadmill.
Here is a video of the problem... Broken treadmill motor - YouTube
I've asked the manufacturer for help and they supplied me with some new motor brushes (16mm) for £15, I've just fitted them and the problem remains.
As you can see in the video the spark seems to be at it's biggest when I put pressure on the belt.
I'm not sure if this is something I'm going to be able to fix myself, and if not I'm not really sure who I should take it to for help.
Any advice appreciated,
Thanks,
Joe
Brushes should be bedded to get the shape right for good allround contact before using on load
Take it to an armature winder or get another one
I know very little about motors,but expert opinions will come along
At a guess I would suspect some of the windings to be dead shorted,this could be the coils of the commutator causing it or the wear off the brushes bridging them
They can sometimes be salvaged by using a blade to clean out the segments undercutting the mica and give it a good cleaning but that may be a step too far
towards the end of the vid you can see that the armature is burnt out/open circuit on some of the windings, get a new armature or better still a replacement motor
this is just my opinion of course
Reply to Faulty treadmill motor in the UK Electrical Forum area at ElectriciansForums.net
Hi - On our small vessel we have a 12v failry powerful motor to run the autopilot, where the power is supplied by the boat's battery bank. On an...
I'm sorry if this isn't in the right place but this is my first time using this forum. I'm also sorry if i make some mistakes but I'm new to this...
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Having to wire around a messed up output for a month or so. Some sort of program corruption is keeping the central lubrication system from...
