Discuss Feed for pir in the UK Electrical Forum area at ElectriciansForums.net
I'm struggling to get a feed for a pir to control 3 lights.
There is an emergency light fed from a klix.
At the emergency light there are 2 fused terminals, permanent feed and Neutral them separate switch feed neutral.
Could I feed my pir from that permanent feed ?
can't see why not as long as the load on the PIR is not to high for the existing circuit.
Reply to Feed for pir in the UK Electrical Forum area at ElectriciansForums.net
I am installing some driveway lights. The customer wants to be able to switch them on from t he house, but also have a PIR at the driveway...
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
I have a small Consumer Unit fed from a 6 amp type B mcb to a 6 amp type B,it only feeds 1 light in a bin store . clearly we have no selectivity...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
