Discuss Fence Lighting in the UK Electrical Forum area at ElectriciansForums.net
I am having my fence updated using the horizontal slats and would like to install some up/down lights.
I am happy with the switching etc im using wireless Quinetic ones.
I was just wondering what is the best way to wire these, do i have to trench SWA along the fence line, up to a JB/Conduit box (hidden by the new fence...hopefully) and then flex upto the lights or can i wire the lights in or before the new fence to save trenching?
Any help or advice would be greatly appreciated Ive uploaded a couple of pictures of what i want compared and my existing fence?
You can probably clip some outdoor rated cable along the horizontal route, it need not be SWA unless being buried directly in the ground (or otherwise at threat of physical damage), or it is not RCD protected (unlikely in any new installation). Something like H07RN-F rubber flex, or NYY-J round cable (not suited to much flexing) is easier to work with.
It would be easier to do before the new layer is added, but you need to take care it is not damaged by those doing the fencing work and ideally the cable ends are sealed up until you install the lights.
Looks nice that. Do the neighbours get the rough side though?
Sir; some advice as if it was my garden - do not install mains voltage lighting down the fence. Use 12V LED lamps instead energised by Safety Extra Low Voltage SELV double insulated power supply inside the house.
These are the sort of lamps I am thinking of:
12V in the garden provided by the appropriate power supply will be so much safer, and as time goes by and the outdoor installation inevitably deteriorates or is damaged will not become unsafe.
Reply to Fence Lighting in the UK Electrical Forum area at ElectriciansForums.net
I am installing some driveway lights. The customer wants to be able to switch them on from t he house, but also have a PIR at the driveway...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Hi I am trying to replace my old white light switches for nice chrome ones but the wires are all red but the new switch has only l1 l2 top and...
Hi All, 1st Time Post, wish I knew about such a forum ages ago!! Anyway, I’m here for some advice on best way to set up some Garden lighting...
5K
