- Reaction score
- 9
Evening all.
Few questions here.
1. What do you find the best way to either protect your back boxes from filling with plaster or to clear the plaster out when doing a second fix to give the best edge.
2, Do you weigh your cable in after a rewire or just scrap it. In addition do you charge extra to remove all the debris made when chasing walls.
3, Skirtings on or skirtings off when chasing in then going into the floor?
4, Do you use the same suppliers on each job for materials and second fix fittings such as pvc sockets, switches extractor fans etc.
5, Iv heard some sparks run a separate cooker supply in 2.5mm for a 13amp cooker just to be on the safe side in the kitchen not to overload the kitchen ring?
Simple questions just things that I haven’t got a handle on yet.
Few questions here.
