Discuss fill a chase in the UK Electrical Forum area at ElectriciansForums.net
T
tedglen2
Hi Everyone. My electrician has now rewired house and has covered the wires in a plastic capping. What is the best way to cover this before it gets plastered?
Well to be honest if your re-plastering the walls .....then the best material to fill the chase in is ........................ plaster.
I would only use a filler if your just cutting a channel in a wall that is not going to be re plastered.
paiunt over the capping with unibond. this will ensure adhesion of the plkaster. forst a bit of bonding, then finish.
weak mix of unibond, then Multibond plaster (it's a rougher plaster that doesn't shrink so much), then finish plaster plasterers job for a good finish)
Most plasterers just prefer you to leave it to them, as they will do it their way. If you are trying to fill it as your own job, then that's a different matter.
Reply to fill a chase in the UK Electrical Forum area at ElectriciansForums.net
Hi I’m getting a new kitchen fitted, there’s a existing socket outlet fitted into a pipe chase, for the rewiring of new socket outlets is it...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Maybe I've just been lucky, but I very rarely have an issue with customers paying, the vast majority have paid straight away or within a few days...
Hi everyone, I intend to bury a 240 volt cable from my house to my barn about 7 metres as way. It will be buried under my tarmaced drive which I...
Hi all I have been pulled up by Napit, not by my regular inspector. Used rcbo's on a rewire (usually do). Filled out cert to reflect this, with...
