Discuss finding a lost camera cable in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
hi ive lost a camera cable in a hotel when plastboarding was done, i have a fair idea but dont want to bust holes and guess..
ive been told a bt tone tester might help me, detect through the plasterboard ????
any help/ideas appreciated
a tone tester might help, but if the plasterers have buried the cable, get the hammer out.
The over 40M might be a problem if the transmitter's only battery powered (normally 9V), as it's not too deep in the wall then s/b able to trace it and find the end. Mine's either battery powered or mains powered from the circuit under test and on full power can detect up to 2M (have a read of the spec).
i generally find that one of these is great for finding lost cables behind plasterboard.
Ours cost about £120 , but that was about 9 years ago now . ( They have come down loads now !)
That one looks like it should do the job , just make sure that you can vary the generator output or it can just flood every circuits in the CU with a signal if you ever use it to find a mains circuit , also if you ever do need to find a mains circuit you will find it a lot more precise if the whole board is off and not just the circuit you are trying to find !
Reply to finding a lost camera cable in the UK Electrical Forum area at ElectriciansForums.net
Hi all, adult learner retraining and sorry if this is in the wrong place but I need help. my provider are being very cards against their chest...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
This is quite lengthy so get comfy... I had a bizarre call out relating to a job I attended about five years ago. The situation was they were...
