Discuss Finding the correct cable table in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A lot of these mock exam questions are not specific about armoured or non armoured multicore cables, flat twin or not etc, the correct table to use can be a bit of trial and error until you get the correct answer for Volt drop for example.
Volt drop for 70°C cable is the same for the same csa and 90°C cables all have the same volt drop for a given csa, type of cable and installation method does not make a difference.
Only CCC is affected by the cable type and installation method.
shirley, though, with the heavier cables, the volts will drop more due to gravity????? :):):).
my bad. must be the electrons that suffer from gravity drop. or does centrifugal force keep them snug with all that orbiting around their respective nucleii.
Reply to Finding the correct cable table in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This might come across as a really daft question to people who work with cable tray quite often but as part of my AM2, I am to clip FP200 to the...
I've got a Fluke 2062 cable tracer. Cracking bit of kit, but very expensive, and isn't getting used very much. I might be open to renting it out...
I have always been of the opinion that this was not specifically dis-allowed as long as the cable rating etc was correct and everything identified...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Correctly closing off a dead twin and earth cable in a loft. My old house used to have radial circuits serving night storage heaters. Those...
