Discuss fire alarm fault and breathe......... in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Not sure if you can bypass earth fault monitoring on these but you shouldn't be doing that anyway. Defeats the object of it then.
If you are on site today and stuck, you could try giving Fike tech support a ring. They are extremely helpful and patient but I think Tazz may have nailed it to be honest with the cable fault.
all sorted , earth fault was on zone 2 but panel shows zone00 NA = twisted cable in the slack in ceiling.
s/c was twisted cable, had to cut holes and lucky it pulled between rooms . short distance = no faults
#lesson to be learned sloowdownniceandgentle
Reply to fire alarm fault and breathe......... in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
I'm installing mag-locks and fire door hold-open magnets at the moment and I'm wondering if any of the cable should be fire performance cable...
any BS 5839 experts know whether CO alarms should be connected to the smoke/heat alarm system ? after completing an efixx CPD it seems they should...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
We have a domestic fire alarm system in some leasehold properties. The existing BRK alarms are no longer available in the UK. These alarms/system...
