Discuss Fire alarm what is this? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Doomed
Called to a hotel where the spark doing a refit took down something and then said that he had no idea what it was so they better call someone else.
I then got called in and I have no idea what it is, apsrt from its the end of line on the fire alrm circuit.
Looks like an old heat detector. It has been painted, if you scratch some off you will probably find the dome is metal.
Old heat detector (not been made for around 20yrs plus).If you are replacing it make sure you check the cable as it could be 30-40 years old.
VERY late to the party with this.
It's a "Life Saver" heat detector; initially manufactured and installed by Minerva Fire Defence and then continued to be installed when they became AFA-Minerva (when EMI merged together).
There is a bi-metallic strip inside, the devices are normally open circuit, when heated up, the bi-metallic strip shorts the alarm circuit to sound it. Some had 220k resistors in.
Most of the systems these were installed on were the CT1 and CT6 panels - these operated from batteries, and powered an inverter.
The Zone pair had 220v DC on it (not 24v as most people would assume).
Reply to Fire alarm what is this? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I'm about to start first fixing this fire alarm in the industrial unit we are wiring, at the moment its totally empty and eventually will have a...
I'm installing mag-locks and fire door hold-open magnets at the moment and I'm wondering if any of the cable should be fire performance cable...
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi, I need to extend a fire alarm, the panel is a CTEC CFP 2 zone one and currently it has a couple of apollo alarm sense sounder bases/heads on...
4K
