Discuss FIRE ALARMS - what do I need to be installer? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
mikex79
Hi
I work with low voltages I install CCTV systems and intruder alarms,
just wonder what qualifications and certificates do I need to be able to install fire alarms? are there any regulations in the UK that have to be followed?
thanks
Fire systems come under BS5839 which details requirments for design, installation, maintenance, etc. Courses aren't too difficult, easier than BS7671 for sure!
Be aware that it's your competence that will be measured if things go wrong, not your qualifications! It's experience you'll be needing...
you ll certainlly need 17th ed plus cg2381 plus registration unless your going to get building control out every time you do an install which will add about £230 to each one, as you need a cert. of installation and test
do i need to be fully qualify in the uk electrician to fit and certify fire alarms or i just need to do a fire alarms course to be able to do that, which course do i need to finish to meet the regulations?
for examlple at the moment i have knowledge and experience only but i am not a qualify neither electrician nor fire alarm engineer but i know everything about the trade though, i would like to work on my own and do it as an one person company, what do i need to have to do that??? does anybody know???
Reply to FIRE ALARMS - what do I need to be installer? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
I'm installing mag-locks and fire door hold-open magnets at the moment and I'm wondering if any of the cable should be fire performance cable...
We have a domestic fire alarm system in some leasehold properties. The existing BRK alarms are no longer available in the UK. These alarms/system...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
