Discuss fire break in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
beaver74
been looking through building regs but cant find the answer i am looking 4
now when ever i install down lights in a down stairs ceiling or ceiling with a room above i install fire rated
but was mentioned today that a room which is in the same property the ceiling is not acualy a fire break ceiling so does not need fire rated
but i feel more at ease using fire rated
your views please
Now that FR fittings are so cheap why would you not? Long gone are days that fitting and hood were £20. Now screwfix do a twist bezel fitting for less than £8 with FP built in. Always play safe !!
Reply to fire break in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi everybody, I've been asked to do a EICR in a commercial property, So i popped in to have a look on my way home quickly and found the lighting...
Hi there fire rated down lights in a dropped false ceiling with no insulation and 2.5 watt LED lamps in cladding in kitchen with room space above...
Hello everyone, I'm wondering if someone could help me with some EICR coding. I am aware that bringing mains tails into a fire rated consumer unit...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
On this commercial building we are refurbishing it has the above fire alarm panel which I think is pretty much brand new, I'm not even sure it was...
