Andy Mc123
- Reaction score
- 0
Am hoping you can help
Following an integral garage conversion, I am after a couple of fire hoods to cover some LED ceiling spotlights.
The lights are in a plaster boarded ceiling which has a garage roof void above (the room is part of an integral garage conversion).
Lights are around 150mm dia (110mm cut out) and about 40mm high plus a small driver.
Can you advise if you know a suitable product please ? There is plenty of access above the new ceiling.
For the proposed product, the building inspector is asking for a data sheet and a copy of the fire test certificate for this item, to confirm it is suitable to prevent fire spread from outside in the loft space above to inside the building, maintaining the integrity of fire-rated ceilings, rather than the normal way it’s used due to the roof void being part of a garage.
I have tried Tenmat, antifire, envirograf and all only have certs for fire going from room below to above, not the other way around.
Am hoping someone has found a solution for this,
Thanks in advance
Andy
Thanks in advance
Andy
