Discuss Fireproof downlights in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
What exactly does fireproof/fire rated mean?
I'm swapping an older halogen downlight for a LED downlight in a bathroom, I was getting confused between fireproof fittings and light fittings that can be covered with insulation. Thanks for your concern.Are you sure you should be undertaking this work? Do you have the correct test equipment to verify the circuit your working on is safe and suitable for alteration?
Reply to Fireproof downlights in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
