- Reaction score
- 14
Hey all.
Not been on here for a while and I have been doing a bit of browsing in this section to see if anyone is in a similar situation but not really.
Anyways, so I’m going to be performing my first full periodic inspection report and of course testing at the weekend and I could do with some advise just to give me peace of mind and help give me a lil confidence boost (I believe I’m a good spark but sometimes need reassuring lol).
The environment is a small commercial/light industrial unit, like a machine fitting shop if you like. 3 phase supply, TNC-S system feeding a 3 phase board with final circuits (60898 and 61009s) and a 63A sub feed to office block which in turn has its own consumer unit (RCD protected 30mA with 100A main switch and again final circuits - protected by 60898's).
Hope the above isn't confusing - please ask me if it doesn't make sense. Now, I actually did some installation work there (supplied power and fitted a 3 phase/neutral and CPC socket) and now he wants me to test the whole site as the periodic has expired (5 years I believe for commercial/industrial).
Noticed that the main gas hasn't been bonded so prior to doing that I will bond it as I’m sure you would agree why do a PIR only to fail it as no bond to gas is a no no and would defo be a code 1 in my mind.
Structural steel work and water bonded so no worries there. Asked the customer if it was ok to view previous PIR paper work to which he happily obliged. On viewing it I saw that there were no major issues other than workshop sockets have no RCD protection (this was down as a recommendation but I have no idea why gas wasn't bonded how the hell did it pass?!)
I have gotten around this by putting in RCBO's so essentially the shop floor has RCD protection now. Now, here is where I am a bit stuck. I want to impress this guy as he will be present whilst I am testing and he has promised me future work. I am pretty comfortable with the testing procedure but one thing is bugging me. In the paperwork it mentioned (can't remember where like but something along the lines of "lighting circuits IR tested with all switches left in the off position").
The lights are basically twin fluorescent fittings (big buggers they are I think 8ft). Now, I am quite happy to take the time to remove all the lamps as I know that doing an IR test with lamps still intact is not healthy and will give bum reading and can damage vulnerable equipment.
My question is this - if I removed all the lamps from the fittings and IR at the board with the switch on will I risk buggering the fittings up? Will it damage the ballasts and stuff?
I don't want to have to tell the customer that I’ve blown his 12 light fittings
He is quite on the ball and told me that if the last IR test was indeed performed with the switches in the off position incl two way setup then the switch wires to the lights (conduit wiring setup) have been omitted form the test and thus have not been tested at all and he wants me to be thorough.
What advise would you give me and would it be safe to test the fittings? What have you done when in this situation?
Many thanks for reading sorry for the waffle J
Sparky05084
Sparky05084
