Discuss first fix for 2x sky boxes in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
dan35
Hi all , i am doing a first fix for a house at the moment and was just wondering if im correct in thinking that if there were to be 2 x sky boxes i would need to run a shotgun cable from each box to the dish position and a coax cable from same position to a booster.?
thanks in advance Dan
disagree. need emmeroids and constipation st. only time i get a bit of peace is when 'er indoors is watching the crap.
Where is the best place to terminate ALL cat5 cables from each TV within the house?
Depends on the system, You can run up to 6 from the broadband router next to the sky box, I think BT do a 4 way router, but you can get a 6 way because I have one, that would give you broadband speeds in up to 6 rooms in the house, obviously you can use wireless, but hard wired a guarenteed fast signal where wireless can struggle in some homes.
mdj, you can buy a 6 way switch for under £50 from currys so sky is the limit.
if you go for your own router get one with a gb/10gb port feeding the switch (1Gb is around 200odd MBps, split 4 ways is 50mb)
put a switch in a cupboard or somewhere that is easy to add to in the future (they can always swap the switch for a bigger one)
the problem with wireless is the ping or in electrical terms the zs is a lot higher on wireless than wired.
Reply to first fix for 2x sky boxes in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hello and good morning all. I am putting in a first fix on a small extension. It will have its own fuse board coming from the main house. I plan...
Hi all, Looking for some advice on first fix for sky and freesat TV, I've quoted a WF100 shotgun and a single to both bedrooms and lounge...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
(Trying again, as picture didn't post first time) Hi, I'd be very grateful if anyone could help me here. Below, I've pasted a sketch showing how...
