Discuss First G59 Application/Notification - Any Suggestions/Help.... in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
J
jwulster
Hi All,
Recently completed our first 10kWp solar PV system but as we kept it at under 16A per phase it was a G83 notification. I am quoting for a 20kWP system that I stand a very good chance of winning so need to know what is involved with a G59 installation. I know about the technical side with string fuses etc but need to know about contact with the DNO prior to installation.
Thanks in advance...
Jonny
Hi All,
Jonny
only have experience with sweb and southern , they are both really helpful but southern have a few weeks back log now , you are only wanting to put 10 kettles worth of power into the grid and they have to make sure its upto it give the dno a ring if your close you can always pop in for a chat
Make friends with DNO first, you will still need to put in a formal application but knowing who is dealing with it never hurts. You also need to put in provision for a G59 relay into your price, just in case the DNO requests one of these, as well as provision for them to witness test the relay. The latter may not be required but you won't know until your G59 application is replied to by the DNO.
Reply to First G59 Application/Notification - Any Suggestions/Help.... in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all I had my PV/Battery setup installed in May and since then all my excess PV is just fed back to the grid for free. When I initially tried...
I (well, the MCS installer) obtained approval under G59 back in 2015 for 11.5 kW of grid connection on a single phase. 12kW of panels into two 6kW...
Hi all, I hope you can help me please. I had solar system installed nearly 2 months ago and my installer turned out to be cowboy despite having...
5K
Hi all, total newbie to the forum. I sincerely hope that those in the know-how would be able to assist me. On my semi-detached house we have an...
