P
Paul Willoughby
I am supplying my garage with power, using a 6mm SWA cable it is 18m from the main CU.
I am digging a trench and following all 17th edition guidelines.
I was originally going to come off of the main CU using a 32a RCBO off of the main switch into an rcd protected 2 way (6a and 20a) unit in the garage.
My issue is that my CU is in the hall and I do not want the SWA terminated through the bottom of the CU as it will look unsightly.
Can i terminate the SWA on the other side of the wall in a termination box (henley block), then bring the connection to the RCBO through the wall with twin and earth.
If so can you recommend a termination box that meets 17th edition guidelines.
Thank you for your help
