Discuss Fitting an extractor fan into a lighting circuit in the DIY Electrical Advice area at ElectriciansForums.net
Toon2309
I currently have the bathroom light wired as per photo via a junction box. I'm needing to add an extractor fan to the bathroom lighting circuit. The fan has three connection points... Constant live, switched live and neutral. I know it needs to go through a fan switch on/off. How do I wire it to the current setup? Can it go through the ceiling rose?
No as there is no permanent live at the rose. You would have to take the feed from the junction box.
What Lee said
Reply to Fitting an extractor fan into a lighting circuit in the DIY Electrical Advice area at ElectriciansForums.net
I've installed a replacement bathroom extractor fan. Pic on the left is the old one. Pic on right is the new one. Wired the same way but the fan...
HI There, I would be grateful if you could help me, I have a very long duct between the bathroom and extractor outlet vent and for sometime, the...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
