- Reaction score
- 18
I am in the process of fitting an in-line extractor fan (ACM125T) that requires a 3A fuse, for a utility room. Vent-Axia have advised That I do need a fused spur, from either the lighting circuit or the ring main circuit (as well as a fan isolator switch).
They also said "the switched live does not need to go through the fused spur, as this is fed to a galvanic isolation on the PCB which separates it from causing harm to the unit".
My easiest option is to take the fused spur from the upstairs lighting circuit (the fan is fitted in the chimney stack in the loft space), but the light switch in the utility room is on the downstairs lighting circuit, so in either scenario it seems to me I would end up with a shared neutral.
Although less convenient, it seems to me that I should take the fused spur from the downstairs lighting circuit to avoid a shared neutral, or am I missing something? I note other discussions on similar topics that I found did not mention the "galvanic separation". Although this separation suggests no current can flow to the other part of the circuit meaning the neutral associated with the permanant live could not be reached anyway... I should mention the Fan is a SELV unit with no earth wire.
