Discuss Fitting dol contactor for 415 v3 phase fans in the Canada area at ElectriciansForums.net
when you said that it needs to swich at 110v, i thought you meant that that was your coil voltage. can you clarify what type of work your doing, and what control gear already exists?
john
I am fitting 2 new extraction 3 phase fans and on the specification the dol contactors must switch at 110v as i have not fit anything yet what would be the best way to do it
Thanks guys i shall have to have a look again at the spec as it could be that malcolm but i seemed certain it said it had to be 110v on the stop start for safety
well you can get away with a 415 volt dol unit but you will have to state you are not using 110 volt to cover yourself.
you would have to use a transformer to step down from 415 or 230 to 110 volts then this 110 volts is your control voltage powering the contactor coil via start stop & emergency stop buttons. if they wanted remote stop buttons in the future it may not be safe to run 415volt cables in the industrial unit
no most coils controlling motor / fans are the same voltage as the motor / fan they are controlling especially when there is only one start stop unit.
if you think about it there is one cable coming in to the dol starter and one cable leaving, both are carrying 415 volts 3 phase
Reply to Fitting dol contactor for 415 v3 phase fans in the Canada area at ElectriciansForums.net
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Guys I have 2 DOL starters which share the same supply for 2 toilet extract fans I have a selector switch wired up and and a set of auxilliary...
I didn't get a picture so will have to wait until I go back again but I've done a crude drawing of what was there. Its in a commercial set up...
I have a sawbench motor that needs an on/emergency off switch fitted, have the hylec on/off switch and a contractor 240V coil with NC contacts...
