Discuss Fitting shelves with built in LED's in the DIY Electrical Advice area at ElectriciansForums.net
soulfool
Hi All,
We're having some shelves fitted that have build in LED's (they're not floating, but will be supported by brackets) and I'm wondering if anyone has any experience in wiring these.
We have 6 small shelves and 2 large ones and want all of the lights to come on via a single switch. We have an electrician coming over this week to prepare the wiring for us, but I'd like to know how these things work.
This is what the sheling company have to say "the shelves are supplied with the rear slotted out so cables can run at the back to a point in the wall where the cable comes through, so all cables will be hidden. If cables can be placed more or less anywhere at the moment that would be great, as you can have your electrician bring out the cables at the point where we slot the shelf (anywhere along the rear centre of shelf and it runs the full length less around an inch either side)".
I'm going to draw outlines on the wall of where each shelf will go so that he knows where to bring the wires out, but how are the shelves then connected to each wire? Will we need to ask him back when the carpenter is fitting the shelves in order to connect them, or is it a simple thing to do?
Lots of people have these types of lighted shelves, so I'm sure the process is straightforward and I'm just over complicating things but any advice anyone has would be greatfully received.
Thanks,
Joe
Welcome to the forum :).
I've approved your thread for the general forum, when admin is next on line you may be assigned DIY status and thread moved but this will not effect any posts made beforehand.
I would imagine they have inbuilt connectors for each shelf a bit like a 'plug and play' set up, please post a link to these shelves also wouldn't it be more prudent to have the electrician fit them as he is less likely to put a screw through the wiring, just saying!
As Stan says I'd definitely get the electrician to connect them up, if when he wires them he 'loops in' to each shelf You will have two cables to connect, depending on the connections in the shelf it could be tight to get the cables connected, an electrician would make sure of solid connections and not trapping wires etc when the shelf is fitted.
I've changed your forum permissions so you should be able to post a photo or two if they're not too large.
Reply to Fitting shelves with built in LED's in the DIY Electrical Advice area at ElectriciansForums.net
First time poster here seeking a little advice/confirmation I have spurred off to a fused switch and from there running two 2.5mm cables to the...
Hi, I'm very new to electrical but I'm ready to learn. For my first project I'm looking to setup 2 shelf racks with four shelves each and about...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
hi im looking to solder solid-color led strips to one power supply for each color, in order to dim each color individually. this is reasonable...
I have had three led strips installed under wall units as part of a kitchen refit. A new pattress box was fitted in a stud wall next to an...
