Deleted member 105018
Hi there folks. Advice needed. Asked to look at an issue with some MR16 LED lamps. Cut a long story short there is 13 x 5w LED MR16s on a radial circuit of length approx 30m long. Lamps placed relatively equidistant along the circuit.
Constant Voltage driver being used (mean well) at 15v to cater for 3v drop over cable length. Supposedly lamps are good for 9-18vdc. Anyway on power up the lamps are flashing. Not flickering. Looks like the driver power the lamps up and then disconnects before trying again. Immediately I thought that the driver may be going into over current on power up but the driver is rated at 100w on a 65w load circuit. Tried a bigger driver (120w) and still the same. Tied the two drivers together (to give 220w) and still the same.
If I remove 6 of the lamps the rest stop flashing and then by adding each removed lamp individually they stay lit properly (which kicked off the over current theory)
Any ideas much appreciated? Thanks.
