Discuss Flat conversion fire requirement in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
R
RGP
ive been asked to convert 3 storey + cellar Victorian house into 4 self contained flats
what would the fire requirements be ??
Local authority will survey when HMO licence is applied for. Most will state, wired full alarm system, call points on entrance, and on each landing area, smokes on each landing, and heats in each flat, sounders to be on each landing and flat. Additional requirement will be solo non linked, mains operated smoke detectors in each flat. and emergency lighting on each floor.
Ive always understood it as HMOs generally have to have shared living spaces kitchens / bathrooms self contained flats dont. Im not sure your description is of a HMO.
As above get building control in they will specify requirements but you need to educate yourself up on the subject so you understand the different set-ups in multi-occupied buildings thus understand their requirements fully or it could be an expensive do'....
Well if the architect designs self contained flats i cant see how it could be a HMO, what the LA want will depend on the design of the building, im sure it may vary between them. Around here flats are not HMOs and do not require a HMO license.
many thanks for all comments seems to be a bit of a grey area will check with LA
If the conversion is done properly with parties concerned it straight forward......when builders dont communicate with LA, then it gets messey....
Supply ok, its been 4 flats previously then converted back to house
Firsted fixed about 18months ago stood empty another 6 months
Now owner wants it converting to 4 self contained flats
So all cables need to be belled out, but it was the fire alarm that I
Thought was an issue
Get conformation first before any install, but should be full system covering common areas smokes, call points and sounders on all landing areas, flats solo mains detection
Reply to Flat conversion fire requirement in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi, I'm completely rewiring a 9 bed 3 storey HMO in Jan, The fire detection required is just some linked lithium detectors in the...
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi everyone, a landlord is converting a house into two flats and wants a separate consumer unit for both flats upstairs and downstairs. He also...
I'm about to start first fixing this fire alarm in the industrial unit we are wiring, at the moment its totally empty and eventually will have a...
