How do you guys terminate these when using flex?
I'm talking these things found in light fittings: https://www.saxbylighting.com/image...a61727463c42674eaa46ff0000f3e563.jpg?sfvrsn=0
I twist the strands together and then try to push them in. The problem is a lot of the time the connection doesn't feel great and often you'll get some strands push back out as you push the wire in, meaning you have to take out, retwist and then redo.
A right PITA.
Is there really no better way of doing this? I thought about ferrules but they don't fit.
So how do you do it with flex?
A right PITA.
