djelectric
I have been searching section 701 but still cant work out the answer to this one..
Can you install a flex outlet plate in zone 2? Bearing in mind it is not switchgear nor current using equipment.. But is also not IPX4 rated.
701.512.2 mentions "installed electrical equipment" shall at least have IPX4 (zones 1&2).
Its for a towel radiator, flex into bottom of faceplate.. Fused spur and timer outside zones.
Can anyone clarify?
Can anyone clarify?
