Discuss Flickering lights on separate circuits in the Lighting Forum area at ElectriciansForums.net
Evening All,
Strange one so after a bit of advice. Got called to a customer this evening who had their boiler repaired after the circuit board got fried supposedly after a power cut when the supply was restored. They were told they needed a switch fused spur fitted as there was no way of isolating the boiler. I turn up to fit sfcu and notice that the supply to boiler is via a 1mm three core and earth. The supply is from 32 amp mcb with Rcd as main switch on Tt. I told the client I am not going to fit fcu until I have investigated a little further as cable is undersized and there must be a jb somewhere. while I was there downstairs lights on 2 separate 6 amp mcb start flickering Intermittently. Being Fri night i am going back sat to get the trusty tester out. Has anyone had this happen before or any suggestions what could cause the flickering. My gut is saying there Is an underlying fault that may have caused the boiler failure Not the power cut.
thank you
Possibly bad connection on tails or incoming cable? If not could even be bad connection where incoming cable is jointed outside.
What kind odd lamps?
Filament and LED can flicker under different conditions.
Is it only one type flickering.
Is the flickering random or more regular
Very likely a loose neutral if 2 circuits are affected.
Other appliances may not show a fault the same as simple lights will, but it could be affecting every circuit.
Good luck finding it.
Reply to Flickering lights on separate circuits in the Lighting Forum area at ElectriciansForums.net
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
Hi everyone. I live in an older home that still has a few circuits with aluminum wiring. One of these is a lights-only circuit that contains 6...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
Hi Guys Looking to see if anyone has had the same issues. I went to a tennanted property last year where the house lights were flickering and all...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
