Discuss Floodlight PIR in the Lighting Forum area at ElectriciansForums.net
Hey People
Mantis here.
Considering installing a floodlight and will be instructing a sparkie. I'm just looking into pricing as I'm after a particular floodlight.
So I have tracked down:
I have used JCC/Steinel in the past with a great experience. However I know floods over 50w generally do not come with a PIR.
Would the following PIR cope with the floodlight above?
Thanks in advance.
Reply to Floodlight PIR in the Lighting Forum area at ElectriciansForums.net
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
Hi all, need to replace a failed 500w halogen PIR floodlight. This one was a dual output model that had an adjustable dimmer on the PIR housing...
Hi All, I will be having a full rewire done shortly and will fit an LED floodlight for the garage and driveway, and one for our garden. My...
11K
Hello All First is my first post, so be gentle on me. I have an existing light fitting. Id like to add a PIR sensor. Id also like the override...
13K
M
Hi, i hope you knowledgeable folks can help! i'm looking for an LED floodlight with a PIR, but with the ability to "override" it with another...
24K
mnbf9rca
M
