Dews84
Hi all help is appreciated
I'm trying to figure out what I am doing wrong
Fluke tester domestic single phase Tncs system
ze test..circuits and main switch open circuit....hi current loop setting on tester......crop clip main earth once removed from busbar... Line to line on supply(live side incoming) of consumer unit neutral lead to (neutral side incoming) press test gives ze reading say .26. Also gives pefc of 910amps.
now from what I under stand I must reconnect main earth and put croc clip on earth bulbar to obtain the true pefc so I do this press test give reding. Now from reading the manual of tester says to press f1 to toggle from l-pe to l-n not moving any of the leads from there position of pefc test to get the pssc result obviously needing to press test again, but here is the problem as the tester makes a buzzing sound and gives no reading clearly it doesn't like it. I have therefore tried this test t. Friends house on another tncs system. Please help this is really annoying me is it because it will only give me a pefc dude to the neutral and earth being one as a tncs system?
If u can help please do and also describe to me the testing sequence for three phases system with this tester
