Discuss fluke 1653 in the Electrical Tools and Products area at ElectriciansForums.net
M
murdock
i need feed back about the fluke 165x series multifunction tester....anyone haveing problems with them error 5....>2000 ohms...inconsistant readings..etc...etc
Having used the 1652 - the leads are the weak point, especially when changing points to crocks.
It would be better if you had 2 sets of leads ones with crocodiles and others with points.
the switched probe?
dont use one myself (although I know they can be easier for IR testing)
what do you mean by packed up? Just wont work at all?
I've got the 1653 only had the odd high reading on continuity, but find squeezing the crock clips sorts that out.
Otherwise found it a fine bit of kit over the past 3-4 years
>2000 ohms ...... make sure the fuse is sat right in the lead, tighten the thread right up.
error5 ............. from memory is excessive noise on the circuit under test, retest or use the scroll button to view test result
Reply to fluke 1653 in the Electrical Tools and Products area at ElectriciansForums.net
I've got a Fluke 2062 cable tracer. Cracking bit of kit, but very expensive, and isn't getting used very much. I might be open to renting it out...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
Hi folks. Im a RECI contractor based in Co Sligo, Ireland . I was doing erroneous testing on a domestic board which gave me readings between 90V-...
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
