Discuss Fluke 1654B loop measurement - how does it measure the Re bit? in the Electrical Tools and Products area at ElectriciansForums.net
sasesi
Hi Guys,
I've just swapped over to a Fluke 1654B MFT and I have a question about measuring the Re using the loop test function.
Anyway, on the full caffeine loop test there is a little button where you can toggle the lower display to swap between PEFC measurement and the Re element of the Ze value. So, I appreciate that the Re value is the part of the Ze value that is just the earth resistance component but, my question is, does anyone have an idea of how it calculates this?
My theory is that seeing as it's a 3-lead test, that it measures the L-N loop value divides it by 2 (in the assumption that the L&N paths will have the same resistance), and then subtracts that value from the L-PE measurement???
Plus, is this test valid for UK supplies and if so, which types? I assume it works for TT but what about TN-S and TN-CS, aren't they just going to show the same value as the Ze reading????
what do you think,
Steve
Re should be the external resistance.
A bit like Ze but without the capacitive and inductive resistive elements.
There's probably a mathematical formula to work this out?
R
E is the resistance of the earthing arrangement of the transformer substation.
RA is the sum of the resistances of the earth electrode and the protective conductor connecting it to the exposed-conductive-parts.
The different letters are quite important.
Reply to Fluke 1654B loop measurement - how does it measure the Re bit? in the Electrical Tools and Products area at ElectriciansForums.net
I saw a Fluke 1653B on Gumtree local to me being sold as faulty. Fault was stated as no continuity between 'N' and 'PE' ports on the resistance...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hello, I have a dedicated loop tester (Martindale EZ2500) and also a Fluke 1662 MFT The reason I have the additional loop tester is often at...
Hi everyone, a few questions here Ze: In the AM2 is it just a 2hi test between L1 - Earth, L2 - Earth and L3 - Earth. Then take the highest...
9K
Ive got my am2 resit tommorow for my live testing and I ran out of time and failed as well as I carried out the ze test on 2 lead high thus...
7K
