Discuss Fluke query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
L
Lucas123
got a fluke 1653 with "err 1" when turned on does anyone know whether this can be rectified at a reasonable cost or is that good night vienna ???
If you download the manual for the tester, 1653 error codes are on page 16, it recommends you send it back to fluke...
I have also read that if you clean the leads this may also help, but I would try and send it back if possible...
Manuals Search
Error 1 is a Self Test Failure usually requires either a Firmware update/reflash (cheaper) or Hardware repair, most often to the input protection circuitry (expensive). If the MFT is less than 3 years old the repair would be covered by the warranty, if you remembered to register it with Fluke.
Reply to Fluke query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Am absolutely gutted, my Fluke 1587 insulation tester appears it's had an unknown fatal incident. I was doing some testing a few days ago and was...
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hi, We are renting and have a electric shower downstairs (extension) - a 9.5kW Triton T80Z fast-fit electric shower as well as a combi boiler...
4K
Hello fellow sparks, I’ve decided to go out on my own. Recently bought a little van and trying to get myself set up whilst keeping my costs as...
