Discuss fluke software anyone help in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
One of my colleagues has just given me his old fluke 6500 (looks like decent bit of equipment )
can anyone advise on software as all the ones I see online don't work with iOS and don't work with windows 10 can anyone give guidance.
cheers
Windows 10 is usually pretty good at running software made for older versions of Windows. It has a comparability mode that you can run apps in, I think it prompts you if it has trouble opening the app up. It could be worth trying the software you have found.
We have Fluke PowerPAT v5.0.11 (2004 edition) running on Windows 7 64-bit. The software sometimes unexpectedly closes, but never loses any data, so is functional. The 21 year old Robin PowerPAT 5000 we use it with is still going strong and never hiccups!
I have heard of people running legacy applications in separately partioned areas on newer machines, however IMO unless you're an IT geek, this seems over complicated, when you can pick up an old Windows 2000 or XP laptop for next to nothing and just use that for your PAT downloads (for example)
Reply to fluke software anyone help in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi All, long time no see. I was having a problem with LED controller failures, so instead of sitting there for hours watching a scope and a...
Getting desperate to clear my small garage, and I have a bit of old red/black T&E. I used a few bits to add a socket or two in my flat and a...
Hello! I'm a bit stuck with this. I'm trying to replace this switch as it's old and it doesn't work with LED lights, with this new one. Can anyone...
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
