Discuss Fluorescent to LED replacement tubes in the Lighting Forum area at ElectriciansForums.net
Got a few 4'(1200mm) fluorescent tubes with ballast and starters.
Although the lumen will be lower using LED, I assume the ballast and starter is by-passed.
Also assume to use the SMD range of LED tubes.
thanks
bin the starter and ballast. feed L to 1 end and N to other end of LED tube ( some tubes want L and N to 1 end and nothing to other, see instructions ), and the light qualityand output will be better as long as you select the correct wattage/type of LED.
As above but Some LED tubes come with a unit ( looks like a starter )that goes where the starter goes , for these tubes you leave the ballast in place.
I've used this type but you don't need to leave the ballast in place. Where the ballast unit has failed and we have upgraded to LED the ballast has just been removed from the circuit.
Reply to Fluorescent to LED replacement tubes in the Lighting Forum area at ElectriciansForums.net
Hello! Hope you’re all keeping well! I’m replacing a fluorescent tube light which had an electronic ballast fitting - I’ve ripped this out and...
Hi: I am the custodian at Peru Public Library, Peru IL. About 20 years ago, I installed about 150 new General Electric brand electronic ballasts...
Hi all, I guess most of you have seen some moving spirals in some fluorescent lamps. Not sure if there's a better description for that, but with...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
Evening. Got my hands on a pair of choke ballasts to run fluorescent tubes a few days ago and I want to see if they're in good condition. If...
