Discuss Flywheel Diode/Snubber Circuit For a DC Coil? in the Commercial Electrical Advice area at ElectriciansForums.net
G
gerard
Hi,
I have a hydraulic valve with a two 24Vdc, 31W coils. How do you calculate the size of the diode to place across a coil to prevent voltage spikes or back EMF?
Gerard
Any general purpose rectifier Diode will do for this application, 1N400X series spring to mind, (1N4001 to 1N4007), these are common and can be got from almost anywhere, Maplins, Rapid, CPC/Farnell, RS to name a few.
Reply to Flywheel Diode/Snubber Circuit For a DC Coil? in the Commercial Electrical Advice area at ElectriciansForums.net
Hi All, I am currently learning about AC and DC supplied coil and have been given the scenario below. I understand the first few steps but then...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
Our old Friedland chime all too often now emits a only faint "ding"- because the person at the door (usually a delivery driver) just "dabs" at...
Lawnmower Generator AC to DC sharing common ground / neutral??? Question is general because I am trying understand fundamentals. I will give...
Hello,I need recommendation for type. voltage,etc diode for toggle switch controller on my fisher homesteader plow.12 volt.since I do not have any...
