Been living in our current house for a couple of years and finally turning our spare bedroom (junk room at the moment) into a useable bedroom. I want to move a double socket a couple of feet to the left so we can fit some wardrobes in so I lifted a floorboard up today to see if it would be easy to move depending on where the cables run and found two terminal blocks as shown in the photo.
I’m guessing this has been installed when the downstairs dinning room and kitchen were knocked through by the previous owners to make the kitchen diner as some of these cables seem to run downstairs.
I’ve never come across something like this in domestic wiring, I’m assuming the terminal with the 5 cables going in is acting as a junction box? but can it have 5 cables going in safely? If so should this really be enclosed / proper junction box installed? I’m not sure why the second terminal block has been used apart from needing to extend the cable to the socket maybe?
All of the electrics in the house are working perfectly and have been ever since we moved in but should I be worried about this or is it ok?
