Discuss Fried mice. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
DHES-LTD
Carrying out a PIR today i took the front off a cooker outlet to find 2 mice welded accross the terminals.
Reply to Fried mice. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have a selection of brand new electrical items 6 MK 422. 1g white telephone socket outlets 2 MK 3632. 2g white moulded...
Good Evening. I’m currently carrying out an EICR. I have a cooker circuit radial with a 32amp mcb fed from and RCD split board. There is a 45amp...
A friend's partner has an interesting fault, if it is a fault. She sets the shut down timer on the cooker and when the timer goes off (which in...
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
Recently moved into a house from the 70s. There's no ceiling light in the living room. Assuming the switch for the room was to one of the outlets...
