Discuss From a recent inspection in the Electrical Forum area at ElectriciansForums.net
No need for sarcasm mushNo, just interest factor, although I suppose it looks modern to you.....
Nice reply, more sarcasm then lol, what action did you recommend rewire or CU change or both????not sarcasm, just gentle ribbing to a loved and respected forum elder
Lower one no, only live fusing, upper picture as I say I didn't dare disturb.Both double-pole fused?
You'll need someone with some experience, of wiring old properties then Doomed, pick me up AM drop me off PM I'll give you a hand if you want. Got plenty of experience of drilling behind large cornices and deep skirting, no qualifications even the standard ones required for that sort of work, just lots of experience.The rubber is so flaky its a rewire recommendation, luckily its only now doing the lighting now (and 2 sockets wired in 1.0mm in one room), its just going to be awkward as its a functioning space open to the public except weekends and the flooring on all levels is one sheet of sealed lino stuff in each room, so there go goes what little social life I had if its accepted.
I'm impressed with your knowledge!The channel fuses don't have flash pads because the fuse wire lies in the outward-facing channel. However, there is often a slot-in insulating partition between the line and neutral sides that is made of asbestos cement board. In this case I think it's missing. It's a 1920s pattern and probably the only board when first wired, usually located centrally e.g. in the hall behind the front room near the ground floor ceiling, fed from a switchfuse at the origin.
Where did you find ACMs in the 8-way board? Any detail pics? It looks like a MEM Kantark Junior board which doesn't have flash pads or asbestos tubes, the fuse wire being contained in a plain tunnel through the porcelain carrier. Larger MEM Kantark products with flat pins had flash pads, but not the 15A Junior. Obviously being SP+N it's much later than the channel fuses and actually pretty good as far as rewirable circuit protection goes. Their main hazard is the lack of touch-proofing of the end contacts.
Would love too, but I think you are too far from meYou'll need someone with some experience, of wiring old properties then Doomed, pick me up AM drop me off PM I'll give you a hand if you want. Got plenty of experience of drilling behind large cornices and deep skirting, no qualifications even the standard ones required for that sort of work, just lots of experience.
The larger board has flash pads set into the board and surface mounted fuse wire on the carriers
The Bad old days Eh Lucien?, some of the Sov installs were DP fused, til I got my Mits on themAh yes, Kantark Minor, not Junior. GEC was Junior. I should be on top of this stuff.
DP fusing is usually now seen as some weird old dangerous practice, but when a lot of these pre-war DP boards were installed, the neutral was not guaranteed to be solidly earthed. An N-E fault could cause an overcurrent that would damage the N conductor unless it was also protected by a fuse. By the same token, a fitting could be live unless isolated in both poles, so there was little disadvantage to the DP fusing leaving a voltage to earth on a seemingly dead fitting if only the neutral fuse was open.
Reply to From a recent inspection in the Electrical Forum area at ElectriciansForums.net
