Discuss Full Calculation of Perspective Fault Current - PFC in the UK Electrical Forum area at ElectriciansForums.net
P
puffy
I seem not to have access to the professional forums so I post this here:
I understand ohm's law and to get a current you use Volts/Resistance (V/R); so if it's Perspective Fault Current (PFC), it's V/R or Volts/Ze; and we divided by 1000 to convert to kA. Yes?
Is there a difference when calculating PFC on either earthing systems? For a TN-S, TN-C-S, TT or IT, is the same formula used?
Thanks.
PFC calc is the same as far as I'm aware, earthing arrangements won't make a difference as in 99% of the time PSCC will be higher than PEFC.
Yes, it would be the same, but more specifically L-E is the Prospective Earth Fault Current (PEFC). L-N is the Prospective Short Circuit Current (PSSC). The higher reading of the two you then record as the Prospective Fault Current (PFC).
Reply to Full Calculation of Perspective Fault Current - PFC in the UK Electrical Forum area at ElectriciansForums.net
Hi - just after thoughts on this please. I've been doing some testing on a 20 year old MCC. On the original EIC, Ze was reported as 0.04 R, PFC...
hi in college and watched some YouTube videos and read up on things I think I got the right formula but I'm not sure. Zsc= Zesc(or Zdbsc) +...
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
Hi there, I'm Currently doing my design calcs for my college project and doing the actual Zs calculation. Formula is Zs= Ze (or Zdb) + (R1+R2)...
I'm installing a new supply to a ceremoniously dumped welfare cabin. I can't see any legitimate reason not to apply section 717, welfare units are...
