hi
Im undertaking a full house rewire with a view to having an NICEIC assesment to get registered. Im not sure of a few things though.
1. Bathroom lights. If i have downlights should the ceiling rose junction box be accesible or should all the wires be connected with the neutrals in the light switch outside or in the pull switch? What is it called when the neutrals are connected within the switch and when is it appropriate to do this?
Above the bathroom is an accesable roof space.
2. Ring main wires buried in plaster. Acceptable?
3. Downlights in front room. They are connected under the floorboards above. Would it have been apropriate to have the neutrals in the light switch as junction boxes aren't accessable?
4. Pir censor in hallway and landing. My bright idea this on. Hall and landing are operated from pir switch with their own circuit connected to house smoke detectors and not on an rcd. Should they have a manual switch as well. Also should the neutrals meet in the switch or should i connect it from the rose?
Any other tips for the assesment would be greatly appreciated!
Cheers.
Cheers.
