Discuss Fuse board upgrade price. in the UK Electrical Forum area at ElectriciansForums.net
UK location
Birmingham earth . :rolleyes: third from the sun
£300 would be typical if I've done a recent EICR and there are no other issues other than a lack of RCD protection. £500 would be typical if I have to do an EICR prior a board upgrade. Obviously the price would be higher still if issues were discovered during the EICR and taken into account as additional work, or if RCBOs were being installed.
try again .
£300? Do you eat fresh air for breakfast, dinner and tea and live in a cardboard box??
Get real, you’ll spend that much on materials of yours fitting anything halfway decent!
Think he lives better than that on £200 for a short days work Dave lol.
https://www.NoLinkingToThis/p/briti...gclsrc=aw.ds&dclid=CKDqp4XA690CFcehUQodeo8JIA
https://www.NoLinkingToThis/p/prysm...mm-x-3m-reel-double-insulated-pack-of-3/92086
£200 for a days work? He’s supposed to be an electrician not a bin-man/tramp!!
Reply to Fuse board upgrade price. in the UK Electrical Forum area at ElectriciansForums.net
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Two questions: 1. I’ve had a bulb in the hall turn black with some white powdery deposits (see photo), whats caused this, guessing i should get...
Hi all, as in the picture, when connecting a 230V cable to a db like this, is there a legal requirement to install external RCD unit? Also, if the...
Apparently Dimplex only guarantee their heaters if they are permanently wired in to a fused outlet. If the socket is only about 600mm from the...
