Discuss Fuse Constantly Tripping in the UK Electrical Forum area at ElectriciansForums.net
At least they didn't do what one spark did to a friend of mine :mad:namely told the customer they had a "faulty Earth" :mad::eek: and promptly disconnected it (CPCs) from a S/O :mad:, I got involved later when instead of the RCD (split load board) tripping the fault resulted in the MCB tripping as one of the legs of the RFC started burning up, they still charged my mate for half a day without even narrowing down the fault :(, some people shouldn't be let loose.
If the RCD never trips with the kitchen sockets off then most probably a live-earth fault somewhere on that circuit.
Water could be the cause, do you have any external sockets, or perhaps lights fed via a fused connection unit? Leaky washing machine or dishwasher? Turn all isolators off for appliances in the kitchen, check cupboards for appliance sockets etc.
If none of that comes up trumps then I'm afraid you would need to get someone else in to test it. Were you at home when the other electrician came? What did he actually do and what did he tell you when he asked for payment?
Unfortunately it didn't happen while he was here so none if his tests showed anything up. He had a little beepy thing that he plugged in to various sockets which showed no faults and he mentioned testing something to do with the fuse box which also showed no faults.
He checked about outside lights but they are on other RCD, and disconnected some external plugs as he thought that could possibly be the problem.
Just unlucky that it tripped about 5 times before he arrived and 10 mins after he left but not while he was here.
It is v intermittent though. We woke up to it tripped on Saturday morning, turned it back on, it went again once, then was fine until waking up this morning. Sometimes it has been an hour or so in between, sometimes immediate.
Old fridge or freezer with a failing compressor?
Please help!
A fuse keeps tripping over and over again. I have 100% narrowed it down to being on the "kitchen sockets" circuit and definitely not to do with overloading or any particular appliance being used.
Believe me, I have unplugged everything in the entire house and it still goes, had one thing plugged in at a time and it still goes, etc. It is not down to one particular socket or thing that's plugged in.
It started randomly in the middle of the night, we discovered it when we woke up. We have not done anything differently recently, nothing new plugged in, no new screws or nails put in walls.
What else could it be please and is it something I can fix myself / if not, will it be a quick/cheap job for an electrician to figure out and complete. I've already wasted £140 today on an electrician who did absolutely nothing.
Firstly I concur with the others this person who ripped you off was certainly not an Electrician, or if he was he needs to give up charging people for his work, a disgraceful outcome from a so called professional.
Did he do any testing with meters etc, sorry to sound negative, but it pees me off no end when some Muppet turns up has a look around, charges the earth and does a runner, certainly hope a forum member close by will be able to help you out, please let us know how you get on, oh one more thing, was this person recommended to you, and can you recall if he was a member of one of the Competent Persons Schemes (NICEIC, NAPIT, STROMA, or any of the others) anyhow good luck. If so you may get some recourse if he is a member of a CPS, by complaining to them, Trading standards is another route for you yo try.
Intermittent fault, could be water as suggested, or rodents??
With the rcd off, does the kitchen breaker feel soft to turn on, more so than the others?
This doesn’t find any underlying problems that caused the trip in the first place, but it does make the mcb trip more frequent.
Night time ,
(what was weather like that night ?-something that wakes light sleepers like me)
Condensation ,wind blown rain
, rodents love the night when they cannot hear anyone moving about !
.... Do get testing done if rodent signs ! ...
(that time of year-- Attic - attack)
N
Please help!
Never heard of a tripping fuse.
Most of the time it's the RCD, sometimes it's the specific kitchen sockets fuse. When I leave that fuse off the RCD does not trip.
I've uploaded a pic of the unit with RCD and fuse pointed out.
I haven't read the entire thread, so what size in Amps is the "Fuse no 6" the fuse that is tripping, something like 6A; 16A; 20A; 32A, etc maybe helpful to know what we are dealing with.
How did you come by this "Electrician" word of mouth or something like "trust a trader" or "my builder" type organisation?
£140 sounds like an emergency callout agency style, you agree the charges before they send someone out, ripoff. Many found on the internet, try a recommendation from people you know.
Previous house had intermittent fault - drove us mad... tripped usually early hours... turned out the dishwasher leak 2 months earlier had finally seeped through tiles and screed enough to get moisture inside a hidden junction box laid in the insulation below the gf slab. The condensation level increasing during the night was just enough. It looked like the builder had smacked through the ring main conduit and cable, bodged a repair and concreted it in! Having traced the dodgy leg we bypassed it and only found the “repair” nice and moist months later when we took part of the slab out for an extension!
Reply to Fuse Constantly Tripping in the UK Electrical Forum area at ElectriciansForums.net
Woke up this morning and tried to turn on the computer (work from home) wouldn't power on, checked lights they worked fine. Went downstairs to...
Hi, I seem to have an RCD that keeps cutting the power at random times without actually tripping, if I reset it, the power comes on and will stay...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
