Discuss Fuse head blank help in the UK Electrical Forum area at ElectriciansForums.net
super
Hi all thanks for taking the time to check in.
basically I'm trying to source the plastic studs you sometimes find on main fuse heads after a knockout is taken out for extra tails to a sub board then later when removed there's an exposed hole with access to the live terminal.ive looked everywhere an no one has any ideas.
thanks in advance for any help.
Good luck with that.
To my knowledge you'll be struggling for a long time to find anywhere that sells them.
A blind grommit (if it'll fit) ? About the best i can come up with.
Try calling the DNO and relay the fact that their equipment has exposed live parts. Be firm and you should get somewhere.
Lamb you legend.
tony it's because I see exposed holes in heads and phase blocks from time to time and not happy to leave these exposed holes when people are routing around meter cupboards and storing stuff in fuseboard cupboards, makes me cringe at these ticking time bombs.
Reply to Fuse head blank help in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Hi I'm looking for some advice for adding a time delay on my parent's shower room fan. My parents had a section of their garage converted into a...
So a quick catch up so you can get an idea… I was asked to do a job for another electrician, as he is too busy. I’m busy myself but said I’d...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
