Discuss Fuseboard change advice in the UK Electrical Forum area at ElectriciansForums.net
Don’t do many fuse board changes, but what’s everyone’s preferred method, as I see people without labelling the old cables swap boards connect up neutrals and earths then leave line conductors last but how do they make sure each correspond to each other so you can identify the circuit like the 1st Line conductor should correspond to the 1st neutral and 1st earth
Each circuit one at a time N and E in the correct place to match the live so on and so forth, years back it was much easier as you had 4 circuits nowadays its easy yo fill up a 15 way with out thinking about it.
Thanks guys I’m just wondering as I’ve been watching some spark and he does all his neutrals and earths first then leaves line last just looks easy to get one conductor wrong but must know what he’s doing
For multicore cables I tend to label the line conductors and then put in the neutral and cpc for each physical cable and then refer to the labelling for each line to place in the OCPDs. However if you have say a small domestic board with cooker, ring, lights on one side and immersion, ring, lights on the other the size of cables makes it obvious and you only need to ensure the immersion is separate from the ring.
If you are not cable tying up the cores and not doing overly neat bunches of cores then just pulling on the line as you prepare to terminate should move the corresponding neutral, but it is a bit hit and miss.
Identification is probably a good idea in all cases, it can be done without labelling on boards so long as you are paying attention and have a good memory however it is generally better to ensure you are correct.
As with some of the others I label the line conductors. You find that you don't usually need to label them all, for example if there is only 1x6mm then you can't confuse it with any other line conductors. I label it by using a bit of insulation tape and physically writing on the tape what circuit it is.
To be honest sometimes I just take a "guess"
I got a decent supply of number labels when i was ordering for the shop
corresponding neutrals and hots were marked with the same number (neutrals with letter n added)
You have to trust that the original board is correct regarding N and E in the same order as L.
I go with small sharpie marks on line conductor, but so far haven’t changed anything bigger than 8 way board.
I use flags and sharpie during the initial circuit testing after identifying what each cable supplies. Old boards tend to have multiple circuits on one fuse which in some cases require splitting onto separate mcb’s . I connect each circuit L N CPC A circuit at a time. Not sure if its the quickest but it works for me.
Consumer units are easy enough;
Dress in the neutrals, earths and then lives which have already been numbered up.
For dbs all depends on the layout..
Usually I will cut all the cables to the same length, number up the cores with wago push ons and then dress in as I go along..
The last few boards I’ve done have been bespoke ones.. Got an enclosure and populated with breakers, contractors, etc all mounted on din rails
Reply to Fuseboard change advice in the UK Electrical Forum area at ElectriciansForums.net
I have a fuseboard change I need to do soon I’m putting in a FUSEBOX 7 or 10 way RCBO+ SPD My only concern is how I should run the pyro cables in...
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
Anyone come across this before? I was asked to do a Zs on a 3ph surge device; L1 was around 6 ohm, L2 & L3 around 0.11. Wired in singles from a...
hello guys, hope you’re all well. We are looking at installing the Hager SFT240 changeover switch to three live aboard boats with an electric...
Need help with a quote here. I’m wanting some sound advice. Was called out to the hot water not working so repaired the issue within the panel...
