Hi,
In the example pic, if the double socket was already a single spur off a socket in the ring main, as I understand you can only have a single spur per socket from a ring, could a fused 13A switched spur for a cooker hood be taken from the spurred double socket, or does this go against the regs?
Is there a way to create an isolation for a cooker hood from the spurred socket?
Thanks!
Thanks!
