Discuss Fused Spur from supply in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the advice. I’ve not bought the fire yet and the store advised to have 2 fused spurs, but thought as the LEDs don’t draw much current and it was not using much power I thought I could use only 1 spur?
Thanks again
Hi - it may be the manufacturer has specified the heater needs a 13A fuse and the lights need a 3A fuse and there’s only 1 fuse per fused connection unit. But it does sound a bit odd.
Wilko, Surely wouldn't the appliance be fused down inside its case into two seperate circuits?
It's very strange that any stand-alone appliance needs two supplies from two seperate spurs. Imagine the horror if there were a large installation with cisrcuits wired across all three pases - and someone connects the appliance across two of them!!!!!!a
I'd be doing a lot more research on that appliance.
Reply to Fused Spur from supply in the UK Electrical Forum area at ElectriciansForums.net
Has anyone come across click accessories spurs burning out? it seems to only be happening with the CNS200 Trend uk Steibel eltron heaters Fuse...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Hi all, Thank you in advance... So I had an electrician put in some FCUs on spurs to a couple of outside lights.. this one was in readiness to...
Hi I have a switched fuse spur where the cooker hood should plug in to… above the actual cooker. I was wondering if I could swap this out for a...
Hi, my friend is having a floating shelf with a electric fire, and I’m between minds where to put the socket, I was gonna put the socket behind...
