Discuss Fusing Fans to manufacturers spec in the UK Electrical Forum area at ElectriciansForums.net
N
nickblake
Well chaps ive been looking at the manufacturer requirements for fusing down fans ,an every one appears to require only the permernant live to be fused so having words with those nice people at scolmore click you can do it easily with the grid range that doesnt actually look like grid fuse and an isolator in the same switch brilliant thats what i say good old Click scholmoreGEDC0500.JPG
Like that, saves messing around wiring in two different items.
probably less than a separate isol. and FCU when you factor in 2 back boxes, never mind the extra cutting out and time running cable.
The click stuff is one of the best thought out at the moment.
i like their grid stuff as well.even on normal plates you can swap a 2way for an intermediate easily.
I get those isolators for about 2 quid, the faceplate for about 90p and a fused unit is around 1.50.
Never thought of doing that and been using the Click mini grid for a while now.
Nice one
This may sound a silly question but how to you wire it if you're using a fan with an over run timer?
as i see it, it's a 3 pole isolator with a fuse in the permanent L.
According to the manufacturers instructions i have read you only need to fuse down the permernant feed and not the switch feed , so ideal in my mind ill let you know the cost
Yep, perm live only on the ones I've seen. I've also noticed that the rule about fusing it only applies to the UK! Anyone know why we're blessed with that requirement here and no one else is?
It is a bit strange, as the whole circuit is protected at 6a. That isolator with integrated fuse on the perm live is a simple but great idea, as said saves the hassle of having to use two accessories. Why does the perm live need fusing down but not the switched live?
They're both fused because of the way it's suggested to be fed (via the perm live). If no other countries need to add protection, then why do we? I don't believe other countries lighting is 3A to start with. I wonder if it's a misunderstanding that has been propogated across the chinese manuf plants.
Not enough 3A fuses were being sold, its a conspiracy I tell ya!!!
If they insist on 3A protection why not just provide them with one installed? Or am I thinking too much?
That's the point mate, they don't ask any other country to add a fuse (so it must be OK without that protection?).
so why don't we all bombard manrose and the like with emails asking why?
If you installed a fuse in the fan then only one of the SL or L would be fused, if you installed two fuses one in each Line then one fuse could go and still leave a live circuit on the fan. You want the fuse before the isolator. As per post #1
but the whole point of the post is that the manufacturers instructions only call for the permanent L to be fused.......is that a mistake on their part?
Reply to Fusing Fans to manufacturers spec in the UK Electrical Forum area at ElectriciansForums.net
Okay, so, I’m currently working towards becoming an electrician and was after some guidance for a job that I’m working on. The property (a small...
19K
Hello, I have to replace a fan with a timer for a client who has already purchased a fan, the new fan requires a 3A fuse as per manufactures...
Hi folks, This is my first post, I hope you're all well and surviving the lockdown. Long story short, I had an electrician who was going to do...
TLDR: is there a legal requirement to have a landlords supply to power an L2 alarm system? Mornin'. Non-electrician, under the cosh from an iffy...
N
Hi all, Most manufacturers state that their extract fans need to be fused down to 3A. I don't know many sparks that actually do this, however I...
6K
