Discuss Fusing of fans to comply with manufacturers recommended instructions in the UK Electrical Forum area at ElectriciansForums.net
Why not just wire the bathroom with a 3 amp fuse to the lighting and fan then wire everything downstream off the fused spur, problem solved
Shouldnt be a sfcu doing the whole bathroom as the ideal of a local isolator is to isolate the fan itself without interrupting other supplies ie.. lights.
I always put a 3a module fuse holder in a click mini 3 apparatus faceplate along side the 3pole isolator. On 1st fix i always mark the loop in loop out cable and they get paired into the top of fuseholder, thus making perm live & sw live 3A protected.
Do i think its OTT. Yes!
Do i do it to cover my own ---. Yes!
Will the fan manufacturer be able to point liability at me if the fan goes up in flames . No!!
Ask a grown-up to explain ;);):)
Are you grown up?
Can you explain what difference the permanent feed being fused at 3A would make to the requirement for RCD protection?
Can you further explain what the discussion regarding fusing both the permanent feed and the switched feed has in relation to the requirement for RCD protection?
Are you grown up?
Whoops, touched a nerve! I did put smilies to indicate it was a joke.
Reply to Fusing of fans to comply with manufacturers recommended instructions in the UK Electrical Forum area at ElectriciansForums.net
Just wanted to get some thoughts from other electricians who regularly do EICRS, does anyone else code a fan isolater with no 3A fuse protection?
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
Installed a new ceiling fan, with no previous light or power. There is a switch in the room that controls an outlet. I am trying to draw power...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
