Discuss G59 relay in the UK Electrical Forum area at ElectriciansForums.net
Good afternoon gents, just wondering if someone could explain to me the need of a G59 relay when using a back up generator. I kind of understand how a G59 relay works, that it open circuits the switch that operates the generator to prevent it sending electricity out to the grid. Also, it is to prevent mains and generator coming into contact, and if so how isn't this an issue with solar PV, which basically does the same thing. Sorry for all the questions, trying to get my head around it. Thank you
You're barking up the wrong tree. A G59 relay is designed specifically for energy sources that do run in parallel with the mains, unlike a traditional transfer relay.
just did a quick google
Why is G59 Protection Needed?
The main reason for the G59 recommendations is to regulate generator applications, so that no generators are connected to the grid without the specific knowledge and permission of the local electricity authority. The principle reason for this is to prevent the embedded generator from sending electricity out onto the National Grid in a dangerous manner:-
For example, let’s say that a cable out in the street has been broken. Along comes the electricity network operator to repair it. They go to the nearest substation and isolate the cable to make it safe to work on. However, in a nearby building is an embedded generator, which suddenly starts up and begins feeding electricity down the other end of the broken cable, making it live. The repair crew would have no knowledge of this, and so would be placed in a potentially fatal situation.
The G59 relay protective device prevents this situation by automatically disconnecting the embedded generator from the mains.
www.connectingindustry.com/ElectricalEngineering/what-is-g59.aspx
Reply to G59 relay in the UK Electrical Forum area at ElectriciansForums.net
Afternoon! Hoping someone has experience working on the ABB gear below. It’s in a Mobile Office/ Welfare unit, supplied via either 230v hook up...
Hi guys I have been tasked with upgrading some old rewireable fuseboards for a food warehouse that runs continually 24/7. I was asked to do an...
Like a host of UK residents recently (230% increase in genny sales apparently), I've just invested in a small (3500W) portable, dual fuel...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
