Discuss G9 LED 240v lamp only lights when testing in the Lighting Forum area at ElectriciansForums.net
I have a ceiling light that uses G9 LED lamps. The lamps does not light when switched on. However, when I put my meter across the power supply to test if voltage is present the LED lights immediately. Once alight and the meter removed it stays alight until switched off. Switch it on again and nothing until I put the meter across the supply.
What is controlling it - a regular mechanical switch or a smart switch or dimmer? If it's electronic, is it definitely compatible with LED lamps of that wattage rating?
Reply to G9 LED 240v lamp only lights when testing in the Lighting Forum area at ElectriciansForums.net
I have a ceiling light that uses G9 LED lamps. The lamps does not light when switched on. However, when I put my meter across the power supply to...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
